2000 Civic EX issues???
Old Jan 9, 2014 | 04:05 PM
daisymaisey's Avatar
Default 2000 Civic EX issues???
So, first off, this is my first car, ever. And I'm quite clueless as to the inner workings of a car. I'm on here to snoop and learn so I don't waste what little money I have on a mechanic who's going to over-charge me to change everything when nothing is wrong.
This being said, my car squeaks. Well, the back of it. When it is running on a flat surface, no issues. Go 70 on the hwy, no sounds. Go over a bump, it sounds like someone stepped on a squeak-y toy. Or is jumping up and down on it for a solid 3 seconds. Mechanic says there's nothing wrong, but I HEAR IT. And, at 7:30 AM before a bio lecture, it's the last thing I want to hear.
Help?
Old Jan 11, 2014 | 06:33 PM
mundy5's Avatar
if you push down the back end, do you hear it? Then it's most likely your struts or suspension component that has become damaged. Squeak usually come from lubricated parts that are no longer lubricated due to damage to a boot or some other protective layer.
Old Jan 13, 2014 | 03:30 PM
I do hear it when I push down on it. What can be done to fix this issue?
Old Jan 14, 2014 | 09:45 AM
mundy5's Avatar
the biggest thing is to figure out where exactly the sound is coming from. You'll need some kind of listening device and figure out it is is the struts (i.e. replace them) or if it is something else. A joint might just need some grease. You'll need to do the hard work. Noise from the back can be from several place. There is no way for anyone to tell from here.
Old Jan 15, 2014 | 02:53 PM
Thanks mundy. I'll be spending my weekend under my car in hopes of figuring it out haha
Mchorne
Jan 10, 2015 08:09 AM
xnailsx
Oct 26, 2010 03:18 PM
DoubleA77
Aug 21, 2009 04:16 PM
MotoFreak806
May 3, 2007 06:44 PM
rickai
Feb 21, 2007 10:39 AM
