2000 civic LX illumination problem
Old Aug 30, 2009 | 07:18 PM
lukesdp's Avatar
Default 2000 civic LX illumination problem
Hey guys, a friend of mine has a 2000 civic LX. recently the illumination stopped working, i mean the whole dash does not light up when the lights are turned on. This is especially annoying because the instrument cluster does not light up either.
I checked the fuse 7.5A, looks good. Is there a problem area i should check when i rip out the dash? The only thing i can think of is either the dimming switch is bad, maybe loose connection to it, or a dead ground.
Any input is appreciated.
Old Aug 30, 2009 | 08:08 PM
check the taillights do they work? the dash lights and the taillights run on the same power supply. if they work then i suggest the dimmer switch.
Old Aug 31, 2009 | 05:49 PM
mundy5's Avatar
yeah, there is a test where you jumper the dimmer switch to see if it lights up the gauge. If it does, then the dimmer switch is bad. If you do a search, you should find that post.
Old Sep 1, 2009 | 05:01 PM
lukesdp's Avatar
Okay, i went to a local junk yard. Ripped a dimmer from another civic, switched the faceplate (different color interior) and popped it in. everything works like a charm again, thanks for the info.
punkass
15
Sep 29, 2010 02:56 PM
Kikkoman
May 25, 2007 08:00 PM
marfong
Mar 17, 2007 10:10 AM
marfong
Mar 15, 2007 10:02 PM
zionhoney
Jul 18, 2005 10:07 AM
