2000 Civic LX Steering Knocks sometimes, what is it?
Old Feb 14, 2006 | 05:29 AM
tarboroheel1's Avatar
Default 2000 Civic LX Steering Knocks sometimes, what is it?
I just bought a Civix LX 2000 and have a couple of issues to work out. first one was the oil pan which I already asked on another post and this steering issue. Steering operates perfect, no lost motion or anything, perfect. I do hear a knocking noise though mostly when turning the wheel to the left at low speed. It knocks just when the wheel is initially turned, it's not continual. It also has a knocking sound when the car is off turning the wheel side to side. I have friends who have the same model and theirs doesn't make the noise as loud although they do make some noise. Is the steering rack out of adjustment? I saw the adjustment sequence in the manual. Thanks
Old Feb 22, 2006 | 10:17 AM
Sphinx_1's Avatar
Default RE: 2000 Civic LX Steering Knocks sometimes, what is it?
I would check my front axles to make sure they are ok and not causing the noise. If that is not it, I would recommend takeing it to a front end shop and having it looked at.
Old Feb 22, 2006 | 12:56 PM
mill$civic's Avatar
humm...this probably isent the anser, but i no on my 2000 civic you can here a noise when you turn because the wires on the LED for the alarm are rubbing against the stearing wheel
Old Feb 22, 2006 | 02:01 PM
Whitelightning93's Avatar
Might be your rack and pinion. I had a friend's car steer fine, its just that every now and then his car would knock then it would instantly pull to one side.
Andrew Hicks
Apr 11, 2013 06:38 PM
gmoney40
Feb 21, 2011 10:26 AM
gmoney40
Feb 16, 2011 04:56 PM
tity04
Aug 1, 2008 08:58 AM
Robertico504
Nov 18, 2005 05:13 PM
