2000 EX, cranks but no start
Old Feb 18, 2017 | 08:00 AM
Jeremy102579's Avatar
Default 2000 EX, cranks but no start
Hi all.
I have a 2000 ex coupe. Been in garage all winter hooked up to a battery tender. Went to start her today, she cranks but won't start. I hear the fuel pump working when i turn the ignition on. It was fine when i put her away back in November. Any ideas or suggestions ?
Thanks
Old Feb 18, 2017 | 10:35 AM
Update:
We checked and its got spark, and also fuel after the filter.
Ideas ?
Old Mar 9, 2017 | 04:32 PM
Duane4238's Avatar
I'd shoot some starter fluid into the throttle body. If it fires, you know the problem is in the fuel system. Just because you have fuel after the filter doesn't mean it's getting to the cylinders.
Duane
Old Mar 11, 2017 | 10:38 AM
tenacity2986's Avatar
My car had the same issue, and it was a ground wire from the ECU. Some manufacturers mount a conductive ECU onto chassis, but Honda has plastic ECU cases. Make sure your grounds are connected because if the ECU says don't start, it doesn't matter what else you replace
Mecca8383
Mar 31, 2014 05:15 AM
honvic
Oct 6, 2013 01:50 AM
jerry814
26
Feb 14, 2007 07:59 PM
Civicracer2910
Jul 11, 2006 03:24 PM
black99ta
Aug 2, 2005 05:24 AM
