2000 Honda Civic running issue
Old Aug 23, 2019 | 06:26 PM
Jayv81's Avatar
Default 2000 Honda Civic running issue
Hey guys. In need of some help. Have a 2000 Civic LX with a 1.6. It starts up, runs for a few seconds, and then as the rpms kick down it stalls out. If I pinch off the return line coming from the fuel pressure regulator the car will run but smoke. As soon as I unpinch the line it stalls out. I've done plugs, wires, cap, rotor, fuel filter, fuel pump, fuel pressure regulator, and coolant temp sensor. Not sure what to look for next
Old Aug 24, 2019 | 09:26 AM
StifflersMom's Avatar
Cat Fuсker
could be the actual regulator is shot or you have a vacuum leak, though it shouldn't stall from just the vacuum leak. I'd replace all the vacuum lines with silicone ones and get a new stock regulator. Easy fix.
Old Aug 24, 2019 | 10:26 AM
Jayv81's Avatar
I'll try to replace all the vacuum lines. Did the fuel pressure regulator already with no change
JeffersonRaley
Aug 1, 2010 10:23 AM
athiker1998
Jul 16, 2009 02:27 AM
DreamTeam87
Sep 24, 2007 03:20 PM
AgentofDarkness
Oct 29, 2005 12:14 AM
FastFwd
Aug 3, 2005 11:14 PM
