2003 Honda Civic Coupe EX AC-Heater Fan Problem
OK,
The new blower motor didn't help. I've still got nothing!!! Argh!
Could it still be the transistor? Could I have performed any of the test wrong by having the battery attached? I didn't test any of **** controls. Could that be the problem?
I'm cursed when it comes to AC/Heaters. My last Prelude had a bad AC and I suffered for 4 summers without AC.
Frustrated.
Frustrated.
Thanks Ron, I'm going to work with my Honda mechanic to redo the test.
As a funny side note, the fan operated this morning at 4:30 am on my way to the airport. Go figure. It didn't work yesterday afternoon, but somehow it works this morning.
I've picked up the resistor as well. I've got a new blower motor and resistor to install once we've reviewed the tests.
Russ
Russ
Hi, new here... I have had the same prob with my 2003 Civic SiR for the last month.
I first noticed my car didn't have AC or heat the day after a really big rain storm.... was using the AC/defrost to keep the windshield clear... was hitting lots of big puddles which couldn't be helped, and I heard a loud noise like my exhaust manifold/downpipe was broken....
Next day, AC/ Heat didn't work at all... fan wouldn't come on.
So, I went to the wreckers and got a Acura RSX blower motor and hooked it up. It didn't fix the problem at all.
No fuses are blown, and no relays are visibly blown.
Then, unhooked the original blower motor and hooked it directly to the battery, and it spun for a sec.
Took the glove box off, and started looking around. Nothing seemed to be amiss. A few mechanically inclined people said it was the resistor/transistor that controls fan that is the prob. Going to take it to dealer on Saturday... hate to do that because it is expensive and don't trust them.
Also, took two pieces of wire and shoved it in to the 2P connector that is for the blower motor, and sparks came out. Don't know if this means anything.
I know what to do, just don't want to rip out my dash board and crack the plastic... is it worth doing yourself, or leave it to the dealer???
Would like to know, as it is getting hot around here!
I paid $180 for a new fan motor (after tests indicated a failed motor). It worked for a while, then went kaput on Saturday. I finally installed the new power transistor that I had purchased and all seems to work properly. I even put re-installed my old fan.
