2003 honda civic ex, starts then dies... help.
Old Jan 4, 2020 | 04:51 PM
Madathonda's Avatar
Unhappy 2003 honda civic ex, starts then dies... help.
okay, this is a 2003 civic ex, stock parts, I just replaced the head, and head gasket, replaced all the valves, ( my first time trying that, but I think I did it right) got everything back together, and went to start it up, it turned over but soon as it gets started it dies,.... I'm hoping I missed something simple, like a sensor, but I'm just not sure,... don't want to take this car apart again if I don't have to, any help would be great, if I figure it out before I get any replies I will update this.
Old Jan 5, 2020 | 04:47 AM
drakon543's Avatar
after doing that particular job the list of possible causes range from a forgotten hose to a problem with the head. did you do the head work while the engine was in the car? im assuming you did the work due to a problem you were already having. so ill start with the easiest potential first if you didn't unhook the battery the ecu is still thinking there's something wrong and will keep trying to run the engine the way it used to be running it. next easy just take your time and look over the whole engine bay for anything forgotten. starting into the difficult is check the intake and make sure its tight and the gasket is in place. its all stuff your probably going to go over but it is stuff that's going to cause your problem. you should be able to tell most of you potential head problems just by popping the valve cover back off. what exactly did you do with the valves? the valves and head get broken in to each valve and exact valve placement. you can't mismatch valve location between thier original cylinders. should have also been marked for which way they were in the seat. if you used new valves the head should have gotten the seats done if not the new valves could have been useless.
Old Jan 8, 2020 | 02:37 PM
Madathonda's Avatar
Hey, thank you very much for the reply, I meant to update this thing, got it figured out,... I messed up the timing pretty good, it was off by about 35 degrees lol,... ( my Bad), got it working great now, thank you for taking the time to reply to me though.
LittleRedd666
Aug 5, 2011 07:21 PM
intenseneal
Jan 3, 2011 08:17 AM
TiggerDX
Nov 17, 2010 01:59 PM
dave_57204
Dec 30, 2007 07:36 PM
mittimj
Mar 21, 2007 07:35 AM
