2004 Civic LED DRL Issue
Old Oct 23, 2020 | 06:03 PM
Braydon Gleeson's Avatar
Default 2004 Civic LED DRL Issue
Hey guys, just got a set of Sealight LED headlights (both high beams and low beams). When I installed them all, the DRL only worked on the drivers side, very dim, and flickering. Passenger side wasn't working at all.
I then purchased some Ignite Anti Flicker Harness' thinking this may fix the issue. When I plugged them both in, neither of the DRL lights work. When I plug one in, the opposite side DRL turns on, at normal brightness but still flickering.
I can't figure it out. Should I buy a decoder instead of an Anti flicker harness? The lights work fine on high beam and low beam with no flicker or issues. My only issue is the DRL, because I legally need them in Canada.
Any ideas??
Old Mar 2, 2021 | 01:12 PM
Richg_19's Avatar
Sid you figure this out. I have the same problem with my sons car only it the opposite. Passenger side drl works but dim and the drivers side doesn’t light at all. High beams work fine.
pehenne
Dec 15, 2018 12:11 PM
CivicMD
Jan 30, 2015 07:39 PM
talk2connor
Dec 29, 2014 03:36 PM
gormac
Jul 24, 2007 04:29 AM
94CivicB18
Aug 19, 2006 10:55 PM
