2005 Civic No Start???
Old Nov 30, 2006 | 03:18 PM
joshydee's Avatar
Default 2005 Civic No Start???
Hiya Folks, just bought a 2005 Honda Civic 1.6 V-Tec SE.... car has been in an accident....Got it cheap.. as a business i repair accident damaged cars and i really liked this one so im gonna keep it for myself, Have a taken a caliper off etc on o/s as im working on the bodywork.. just can't get it to start... Turns over and sounds like its going to go but won't is it becuase the braking system isn't pressurised? so it is a safety feature? just wondered if there is something im overlooking or a common fault?
thanks
josh
Old Nov 30, 2006 | 03:27 PM
Solid_Snake's Avatar
Default RE: 2005 Civic No Start???
2001+ civics use a passive immobilizer system, the keys have a transponder which have a code, in order for the engine to start the ECU needs to read the code that its stored in the ECU. If the ECu doesnt read that code from the key you are using, it wont let the engine start.
Hope this helps
Old Nov 30, 2006 | 03:30 PM
joshydee's Avatar
if this is the case wont there b a dash light to say this?
Old Dec 1, 2006 | 02:15 AM
joshydee's Avatar
bump.... So how would i know if this is the case? the red LED under the clocks isn't flashing.... its off?
Old Dec 1, 2006 | 01:41 PM
joshydee's Avatar
Right the light isn't blinking so it accepting the key and turning over..... im thinking fuel supply?.. would the recovery people immobilse the fuel supply somehow? ive checked the fuel pump fuse and that is fine..
thanks
josh
David_S
Oct 24, 2013 10:06 AM
dsvedy
Sep 18, 2011 02:33 PM
pownstarz
Apr 19, 2010 12:30 PM
ws6formula
Dec 24, 2009 04:38 AM
loci
Nov 15, 2009 04:59 PM
