2005 DX Starting problems.....
Old Mar 11, 2009 | 02:05 PM
$RiCh$'s Avatar
Default 2005 DX Starting problems.....
I have been having a problem with the car starting on the first try. Sometimes it starts right up and everything is good and sometimes when it I turn the key there is kind of a long delay and it starts and then theres times when it wont start on the first crank but it will start right up on the second. Has anybody else had this issue?
Old Mar 11, 2009 | 02:51 PM
Hard to say what the problem is. When were the spark plugs last replaced? You might also consider replacing the fuel filter. Is the CEL ON?
Old Mar 11, 2009 | 03:23 PM
rburch77's Avatar
sounds like it could use a tune up. cap, rotor, plugs and wires.
Old Mar 11, 2009 | 04:15 PM
lowlife9's Avatar
Banned
i have that problem with my 2004 dx but it's been sitting for awhile with fuel stabilizer in it a shot battery that won't hold a charge so i have to keep it disconnected so the computer has to reset and there no cat so it could be a bad battery or fuel filter maybe. i do have new denso`s iridium plugs and i did a complete tune up timeing belt transmission flush plugs all that before it sat.
Old Mar 11, 2009 | 04:34 PM
$RiCh$'s Avatar
Well i havent changed the plugs...it is currently at 67000 miles....I bought the car used at 55000...I took it to the dealership and they said there is nothin wrong with it but there is....I was told to change the fuel filter but when I went to autozone to buy one they said that my car didnt have a fuel filter so i dunno what the problem is
Old Mar 11, 2009 | 06:01 PM
mudferret's Avatar
Originally Posted by lowlife9
...computer has to reset
Your mileage must suck! Not sure how long the Honda ECU takes to relearn air/fuel, but my 4runner mileage is awful for 2-3 tanks.
Old Mar 11, 2009 | 06:19 PM
lowlife9's Avatar
Banned
wow they are idiots of course you have a fuel filter its located under the back seat and is a pain in the azz to replace look for a diy or just have a mechanic do it
Old Mar 11, 2009 | 06:44 PM
I forgot about the pain in replacing the fuel filter in a 7th generation Civic.
In the case of a hard starting problem, the manual suggests to check the battery and measure the fuel pressure (see diagrams below). AutoZone will check the battery as a free service, but you might want to clean and tighten the battery connectors first.
Old Mar 12, 2009 | 07:00 AM
Beretta's Avatar
Before you go through to much trouble and start replacing things first check your main engine ground. I had a similar problem where the car acted just like it had a dead battery sometimes and other times it would start up just fine. It turned out that the screw on the main engine ground had just come loose. I found out the hard way though, after replacing the battery, starter and alternator.
kingmike678
Aug 12, 2011 06:20 AM
loci
Nov 15, 2009 04:59 PM
colinwd18
Aug 12, 2008 12:31 AM
zcbh60
Jan 12, 2008 07:32 AM
totenkopf
May 31, 2007 03:36 PM
