2006 civic cyl 1 MIS fire, all 4 white plug tips
Noob here.
OBD II code: P301
2006 Civic w/ 148,000 miles. fresh Denso Iridium plugs at 101,000. therefore only 50,000 miles on new plugs. One owner. As of 5-11-12 Fresh oil change, Coolent within operating range.
from the research on white tips i have found the following: coolent (fins not working properly,low), headgasket, leaking, low oil, low octane.
Anything you DIY or mechanic can help out with?????
Thanks!
-z
OBD II code: P301
Thanks!
-z
Have you considered that it may just be a bad coil or plug? Replace the plug, if the misfiring persists swap the coil with a different cylinder (I suggest #4, as it is farthest away in the firing order), and see if the problem follows the coil. If it stays with cylinder 1, swap the fuel injectors next.
I don't think the 2006 has adjustable valves but I'm not familiar with the late models. The ones with adjustable valves can misfire because the valves need adjusting.
steve5673
Oct 21, 2013 05:15 AM
toverby
Jan 2, 2010 09:39 AM
