2007 ex wont crank
Old Aug 29, 2014 | 06:42 AM
CMonreal's Avatar
Question 2007 ex wont crank
Can any one help, 2007 ex sedan wont crank, new battery , starter removed and checked its good, all lights and power on , starter relay replace still no crank, is there any ignition problems anyone knows about, checked terminal connections, perplexed.
Old Aug 29, 2014 | 02:21 PM
You can test the battery, starter and the connections between them on the car by jumping a test wire from the battery + to the small terminal on the starter. If that works you'll have to trace through the fuses and switches inside the car. Is it a key switch or a push-button start?
If you hear a noise from the starter but it doesn't crank, investigate the possibility that the the engine may be seized. Try to turn it by hand with a wrench on the crank bolt (key off).
whitecivic2007
Apr 28, 2013 06:46 PM
zerojett
Oct 18, 2011 03:01 PM
mike95691
Nov 24, 2007 05:29 AM
rx9790
Feb 28, 2006 05:55 PM
