2008 HCH 12v problem
Old Feb 8, 2015 | 02:39 PM
supradave's Avatar
Default 2008 HCH 12v problem
Took it to the dealership and they said I needed to replace the IMA battery, which I did, IMA indicator was on, now off. Now the 12v battery won't charge. I have a clamp meter and have 3 amps on ground, the red (+) wire between the fuse box and the battery, the little wire from red to wherever and 0 amps between red and the engine.
I'm at a loss on this problem.
Is there a fuse between the generator and the battery?
New 12v battery as of yesterday. I can throw the charger on it and the car works temporarily.
Old Feb 9, 2015 | 08:10 AM
supradave's Avatar
Default 12v cont
Why is there no information about the 12 volt battery? I'm sure there is, I just can't ever find any.
Old Feb 9, 2015 | 03:59 PM
supradave's Avatar
I guess there shouldn't be amperage between the starter and battery (after a closer look).
Does the HCH require a special battery that's not available from O'Reilly?
Antipode51
Dec 14, 2012 10:24 AM
ledezma2003
Jan 29, 2012 07:17 AM
earth80
Sep 22, 2008 05:25 AM
ivanovmrp
Jan 3, 2006 08:07 PM
