2012 Civic doors won't unlock.
Old Feb 27, 2012 | 07:43 AM
Dashteifel's Avatar
Default 2012 Civic doors won't unlock.
My wife came in this morning and told me she couldn't get into her car and wanted to try my key. I went out and this is what I found.
- The FOBs cause a bit of a noise inside the car but aren't unlocking the doors.
- The FOBs will open the trunk.
- The FOBs will arm the alarm. (lights flash and horn beeps)
- The only manual key hole is on the driver's side and the key itself will not turn in the lock.
- Its not cold enough here to be frozen.
I called the dealer and they just told me to call roadside.
-Now I ask the PROs!! Any ideas??
-Dash
Old Feb 27, 2012 | 08:58 AM
Dashteifel's Avatar
Default More Info
I crawled thru the trunk.
Started the car to see if it was battery issue, but it started no problem.
Hit door unlock button, 3 doors unlocked but not the driver side.
I tried pulling the lock lever to unlock but it won't move at all.
Old Mar 10, 2012 | 11:38 AM
Dashteifel's Avatar
Default Fixed!
Took it into Honda and luckily they had another person with 2012 sedan with the same issue. They replaced something in the door handle then re-greased the linkage wire.
I used my iPhone to take a video of everything when it wasn't working. That was very valuable because they wanted to hold my car over night so that they could see how it didn't work. I pulled up the video and they set up an appointment for it to get fixed.
Old Mar 10, 2012 | 05:50 PM
2012 Si's Avatar
My 12 Si trunk will not unlock with the fob. It worked once and the man release works. I hate to take it in for anything but will anyway. I'm sure some sob will want to "road test" the car.
cmpr611
Jul 21, 2010 12:10 PM
Tinkerbell_too
Jan 17, 2009 10:56 AM
Lambo Civic
Feb 16, 2008 09:02 AM
CivicMan33
Nov 23, 2007 10:16 PM
appleaday3k
Oct 1, 2006 03:44 PM
