87 CRX DX with fuel problems
Old Apr 25, 2010 | 11:04 PM
ducati888superbike's Avatar
Question 87 CRX DX with fuel problems
I have an 87 CRX DX that runs great until you have to floor the thing . Then it starts bucking and hesitating and if I back out of the throttle and gently get back into the gas then it picks up and runs like a rocket. I have a friend that lives next door with the same car , so I took his complete ignition system , including the coil, distributor , and wires , installed them on my car. This made no change in my cars problem , so I know its not related to my ignition at all. I believe that there is a problem with my fuel pump or my fuel tank pick-up. If anybody has had this issue with their carburetor'd CRX , I would like to hear from you . thanx Eric
Old Apr 26, 2010 | 04:31 AM
have you changed the fuel filter? you may have a weak fuel pump
ive had a 87 carb crx and a 85 fuel injected crx si
Old Apr 26, 2010 | 06:24 AM
When you first floor it, it's running off of the gas already in the bowl. Weak fuel delivery would let it would run fast for a few seconds, then it would starve.
Having to press the pedal down slowly, but then it will run OK wide open, probably means the accelerator pump is not working.
Ah carbureators, it's hard to believe people get nostalgic over them. Good riddance I say.
Ed Fisher
Jun 15, 2011 08:27 AM
seriously_furious
Aug 14, 2006 08:49 PM
TheBlackCivic
Jul 16, 2006 11:45 AM
89crx
Sep 10, 2005 09:24 AM
nightrider46
Aug 23, 2005 03:42 PM
