89 civic dx no spark
Old Jun 11, 2009 | 10:32 AM
lakahahahman's Avatar
Default 89 civic dx no spark
i have a 89 civic dx 2dr hatch 1.5 litre auto
it just died on me
since then i have figured out no spark
i have changed the computer as well as the distributer as well as the main relay
and the car still wont start there is no spark
i am kinda at a loss here as what to do
any advice would be greatly appreciated
oh and the parts i replaced were from wrecker and a running vehicle i tested the car myself before pulling the parts
Old Jun 11, 2009 | 12:42 PM
First check is to make sure the cam and distributor rotates when you crank. If not the timing belt is bad. This will of course cause no start as well as no spark. Easiest way to check is to take the oil cap off and look in at the valve rockers, which should rock.
Check that power is reaching the distributor. It should have battery voltage on the larger wire in the plug with 2 wires both with the key "on" and while cranking.
If you have a "check engine" light on the dash (not sure if the '89 does, though later 4th generations do) it should come on and go out when you click the key "on" but don't start. This proves that the computer is powering up and running to some degree.
Old Jun 17, 2009 | 07:59 PM
actually that is what i checked first
the car started once i let it idle for about 15 minutes but as oon as i touched the gas it stalled and would not start again have lots of fuel had a guy check pressure and said it was good
but no spark
Old Jun 17, 2009 | 09:42 PM
joukaishou813924's Avatar
is there power running to the distributor?
if so then id check the wires next
if not, like someone said check the timing belt
Old Jun 17, 2009 | 11:14 PM
timing belt is good
there is power to distributer
brand new distributer
new wires new plugs
new main relay
changed computer
this is third dist and computer and main relay
Old Jun 17, 2009 | 11:15 PM
new cap rotor coil condensor or whatever it is called in side of dist
Old Jun 18, 2009 | 05:37 AM
You say then that it did start once, then died?
Check for loose wires, especially the ground wires on the thermostat housing. The whole computer system grounds there.
Make sure you have the plastic plate in place under the distributor rotor; without it sparks can jump down into the low-voltage parts in the bottom of the distributor and burn things out.
wongthao
Nov 17, 2006 05:22 AM
boostnub
Oct 25, 2006 05:59 PM
rok_spitfighter
Oct 18, 2006 02:05 PM
onetrackmind
15
Aug 18, 2005 08:06 AM
jnash
May 17, 2005 12:19 PM
