89 Civic engine blown questions
Old Jun 24, 2007 | 06:17 PM
derekhay's Avatar
Default 89 Civic engine blown questions
My 89 civic has been leaking oil for the last 2 years into the cylinders and the spark plug area.I've just been topping it up every couple of weeks and it has been fine so far. Today i was driving it up a mountain road (very steep) and the check engine light came on and there was a lot of black smoke behind the car. It still runs but very rough and very little power. Just wondering what I should do. I figure the car is worth about $1000 if the problem was fixed. Should i just junk the car or would it be cheap to fix? Fill me in on all the details. Thanks a lot.
Old Jun 25, 2007 | 08:03 AM
Default RE: 89 Civic engine blown questions
Check the compression to confirm a blown engine. The engine may not be blown though, black smoke typically results from running too rich, for example the fuel pressure regulator, fuel injector, etc.
Old Jun 25, 2007 | 01:00 PM
Oldvic's Avatar
If you decide to junk it, I'd be interested in the throttle body.
Thanks
Old Jun 25, 2007 | 04:18 PM
Roadkillboy0's Avatar
yeah if you decide to junk it i could use some of the body panel parts and stuff
Old Jun 26, 2007 | 08:46 AM
adrian64's Avatar
yeah, get a compression test done to confirm.
oldguy
Mar 17, 2007 01:03 PM
Steve Court
Nov 21, 2006 11:48 PM
Xtreamist06
Aug 30, 2006 09:14 PM
jf98ex
20
Aug 26, 2006 05:23 PM
