89 Civic Si Turn signal not working
Old Sep 10, 2007 | 05:05 PM
DaveN's Avatar
Default 89 Civic Si Turn signal not working
Hey Group - great forum! I have a very worn out 89 Civic Si (370,000 Km/222,000 mi, original clutch, still runs great!) that has never had electrical problems...until now: the right hand turn signals do not light (including dash light). Flasher clicks, but no right signal...left signal works, 4 ways work - all bulbs OK...and new flasher relay made no difference. From what I can tell on wiring diagram (OK its the one in Haynes for up to '87 - I imagine not much difference on '89), most wiring is shared with 4 ways, and they work in and out....any ideas? This is driving me CRAZY
Thanks for any help!
Old Sep 10, 2007 | 06:24 PM
Masonn's Avatar
Default RE: 89 Civic Si Turn signal not working
have u checked any fuses?
Old Sep 10, 2007 | 06:31 PM
DaveN's Avatar
fuses are good...just doesn't make any sense. I thought might be switch itself, but the flasher works when lever moved...just no lights work. And since 4 ways work, I knowwires to lights and the bulbs are all OK...weird.
Old Sep 10, 2007 | 06:49 PM
Masonn's Avatar
have you checked that everything inside the signal light switch inside the steering wheel column is tight? It could be that one way is lose and is not engaging... It's worth a try. lol
Old Sep 11, 2007 | 10:08 AM
DaveN's Avatar
I will have to pull the wheel and check that soon if I can't find anything else....otherwise, I'll have to plan routes with only left turns I guess...
Old Sep 11, 2007 | 10:33 AM
danomatic93's Avatar
June 2010 ROTM
OR, check to make sure your hazard switch is connected and properly functioning. The hazard switch is on the same wiring line and if it doesn't work, your blinkers won't work. Also, check to wiring to and from the switch.
Old Sep 12, 2007 | 06:06 AM
DaveN's Avatar
This is what confuses me on all this...the hazards work fine (I call them "4 ways"...I am Canadian, eh!). My only guess is itts in the turn signal switch itself, but the flasher does "click" when the lever is moved for right signal, so the circuit through the switch is closed, but no lights come on. I am wondering if the new flasher I puit in is faulty...but this would seem too much of a coincedence that it would act the same as the original Honda one it replaced...I am stumped.
Old Sep 12, 2007 | 10:03 AM
June 2010 ROTM
Damn, sounds like you're going to have to follow wires with a wire probe. So... if the 4-ways (hazards) work properly and it's only right signal when "activated" that doesn't work, I can only conclude that it's the turn signal lever that is at fault. I would start by probing the right turn signal wires at the signal lever. I'd be easiest to replace the signal lever instead of fixing it, normally.
Hoopty
Apr 20, 2010 02:00 PM
Hoopty
Mar 21, 2010 04:47 AM
ChillyPhil
Nov 7, 2008 04:49 PM
ToRcHeD
Mar 19, 2007 11:10 AM
rmvols31
Oct 31, 2006 01:49 PM
