90 Ciivi w/D16AZ motor problems
Old Apr 26, 2008 | 01:42 PM
MoparSteve's Avatar
Default 90 Ciivi w/D16AZ motor problems
My nephew hasthe above mentioned car and it has developed a problem. Ever now and then it will not crank. Just turns over and nothing. I found today by disconnecting the negative battery cable and waiting 10 or so seconds then hooking it back up it would crank right up..
Any Ideas on what is causing this?
Old Apr 26, 2008 | 02:02 PM
Default RE: 90 Ciivi w/D16AZ motor problems
Is the engine no-start condition associated with weak engine cranking by the starter? If so, disconnecting and reconnecting the battery may have improved electrical contacts between the battery terminals and connectors. Try cleaning them well to see if this resolves the problem.
kman92civicsi
12
Nov 11, 2006 10:22 PM
topdogmancivic92
Aug 28, 2006 09:12 PM
dalifts
ED-EF Swaps
Apr 16, 2005 01:11 PM
hypnotixcrx
Mar 1, 2005 10:10 AM
nwhite82
Dec 2, 2004 01:49 AM
