91 Honda Civic Idle surge
Old Jun 14, 2007 | 05:59 PM
brinriha's Avatar
Default 91 Honda Civic Idle surge
Hey forum,
Ok will I used to have a 1993 civic with a dead cylinder. Well I picked up a 91 honda civic 1.5 4psd BASE or STANDARD as they call it. No air, ps, or pw/pdl. Its the stripped down version. I only use it to go back and forth to work about 120 miles a day. My Question to you is: When I start it up in the morning everything is ok. It drives just fine. At about 40 minutes later the idle is high and won't go down. Eventually it will go down later. (this happens after I have been on the highway a while and need to stop somewhere) Is there something I have to check or replace. Any help would be greatly appreciated. thanks,
Brian
Old Jun 14, 2007 | 07:52 PM
Default RE: 91 Honda Civic Idle surge
Either the throttle cable is binding, gunk in the throttle body, etc. or the idle air control valve is sticky. Pull on the throttle lever and make sure it is fully closed. If so, clean or replace the IACV. I think the one from the '93 will fit it if you still have it.
Old Jun 14, 2007 | 10:53 PM
brinriha's Avatar
Hey thanks a lot mk. Do you have a picture on where it is or describe really well where it is. Yeah when I find it I will just swap it with the 93 one. Good Thinking.
I do appreciate it.
Thanks,
Brian
Old Jun 15, 2007 | 04:49 AM
On the '91 with throttle body injection, it's on the top of the intake manifold, on the part that leads to the #1 cylinder. There are two bolts holding it on. It also has two small water lines on the side and an electrical plug on the end. On the sequential injection car it will be on the back of the throttle body.
Looking at both of my cars ('91 and '95) now I see at first glance they look the same, but they different in the spacing of the bolts and the placement of the water lines. Not going to swap.
Old Jun 15, 2007 | 06:07 AM
brinriha's Avatar
yeah I was looking at pics. They do look different. So I will clean it then. Is that right.
Where do you live MK?
dstig1
Oct 21, 2014 07:29 PM
1991civic2012
Jan 13, 2013 01:08 PM
ECLCUSTOMCARS
Apr 12, 2011 07:25 PM
gib
Jun 1, 2008 04:08 PM
screwd_up
Jan 28, 2008 03:48 PM
