91 si with D15bVtec NO START HELP! plz
hey guys well all ready to start it cranks n cranks but wont give go do u no what the problem might b...
we installed a d15b vtec obd1 into 91 civic si i have a jumper on the ecu running all the wires to were they have to go only one not connected is vtec pressure sensor n converted dizzy to obd1
everything else hookd up vary nicly but now i got a constant crank but no start HELP!! Please
okay thanks ill let u no whats up n i dnt here the fuel pump priming now that u mention it do u no what can cause that ...ill also check rotation on the spark cables but only ecu codes i seem to get is one long flash to another long flash n short flash..then i get one long flash to another long flash n 2short flashes
did you check all your fuses also?
1 long blink = 10
each short blink =01
so your saying your getting codes 21, 22?
21 Spool Solenoid Valve
22 Oil Pressure Switch
1 long blink = 10
yea that looks to be what i am getting but that wont interrupt starting would it.
well no i got fuel priming its cranking n poping lik wants to go on sounds but a back fire what do u think it could be
Check whether hood fuse #37, hood fuse #34, and dash fuse #14 are blown.
Did you forget to connect or tighten the important ground wire on the thermostat housing?
Have you checked the mechanical timing?
Are the fuel injectors getting power?
What color is spark at the plugs?
