92-95 low beam problems
Okay, At 1st i just turn on my low beam it works than i turned it off than it just never worked again. I check the bulb still good, checked the fuse still good. So whats the problem guys and how to fix it? I got a 94 honda civic hatchback
The diagram describes exactly how to test whether the combination switch is faulty. Do you have a specific question about the tests?
Unplug the switch and put a jumper wire in the plug (on the car side) between F and I. Be careful not to touch ground with your wire.
This test bypasses the switch entirely. If the lights come on low beam when you do it, the switch must be bad.
blackseries99
Jan 3, 2013 12:27 PM
yamahaSHO
Dec 18, 2006 02:50 AM
coronakid
Sep 6, 2006 10:40 PM
liliechen
Dec 25, 2005 11:15 AM
