93 Civic 1.6 No Start
Old Jun 4, 2007 | 06:22 PM
Rxtc's Avatar
Default 93 Civic 1.6 No Start
I have 12V to the starter, and the starter tests good, but no signal for it to engauge, I am stumped, wher should I look next?
Old Jun 4, 2007 | 08:07 PM
brokenarmboy19's Avatar
Default RE: 93 Civic 1.6 No Start
fuses loose wires you know
Old Jun 4, 2007 | 08:43 PM
Rxtc's Avatar
all the wires under the hood are tight, fuses in under the dash are good, although none seem to be labeled for ignition, under the hood by the battery are all good, is there a relay somewhere?
Old Jun 4, 2007 | 09:53 PM
bmxchickie's Avatar
what does it do does it at least click when trying or do you get nothing
Old Jun 5, 2007 | 03:09 AM
Rxtc's Avatar
nothing, no click nothing
Old Jun 5, 2007 | 07:29 AM
theredsuit's Avatar
Check your main Relay, it's located above your left foot just under the dash and is attached with a 10mm bolt.
Pull the cap off and examine very closely the solder points. Look for circular cracks where the pins come through the green circut board.
Old Jun 5, 2007 | 09:09 AM
Rxtc's Avatar
pulled it, looks good, smells a lil funny, is there any way to test it?
Old Jun 5, 2007 | 05:09 PM
Once you have the main relay apart don't bother testing or even inspecting it, just resolder everything. It's a good preventative measure. I'm pretty sure the main relay won't cause a failure to crank though. The starter circuit engages the main relay, not the other way around.
There is a safety switch on the clutch pedal if manual or the transmission if automatic. Also I think the manual has a relay involved with the safety switch. And of course (duh) the key switch itself is a remote possibility.
Old Jun 6, 2007 | 03:19 AM
ORIGINAL: Rxtc
Turn key to ON position (motor not running), CEL should come on, then you'll hear a CLICK sound as the CEL goes away. If all this happens, main relay is fine
David_S
Oct 24, 2013 10:06 AM
honvic
Oct 6, 2013 01:50 AM
pownstarz
Apr 19, 2010 12:30 PM
bmelloh
May 16, 2009 08:01 PM
Ronin Inc
EG Swaps
Jul 10, 2008 06:29 PM
