93 Civic EX fluctuating idle
Old Dec 18, 2005 | 09:07 AM
MR2nCivic's Avatar
Default 93 Civic EX fluctuating idle
Hi all i am scraching my head on this problem and want to get some out side prospective on it my 93 civic ex weather its cold or at operating temp revs betwen 1000-3000 in a smooth patern every time this happens weather its parked or if im driving and come to a stop it will start agin. here is a list of what i tryed allready.
map sensor
egr
plugs
plug wires
rotor
cap
check the puls going to injectors
cheked spark
checked for vacume leaks
checked timeing
might have done more but there all kind of running together right now lol but any help would be great.
Old Dec 18, 2005 | 09:55 AM
nasty97ex's Avatar
Default RE: 93 Civic EX fluctuating idle
had that problem before, throttle position sensor
Old Dec 18, 2005 | 05:08 PM
MR2nCivic's Avatar
thank you i will try that in the morning
Old Dec 18, 2005 | 05:23 PM
95CIVICUS's Avatar
can you adjust that sensor to where you can fix it w/o replacing it?
Old Dec 19, 2005 | 10:32 PM
MR2nCivic's Avatar
no you cant and i have found that no one has just the sensore. and when i called honda you have to buy the throtel body and sensore together cant just buy one or the other [:@]
Old Dec 20, 2005 | 02:49 PM
MR2nCivic's Avatar
thanks for the help i replaced the throtel body and TPS and that fixed the problem thanks nasty97ex
Old Mar 1, 2007 | 07:25 AM
C1V1C_C0UPE's Avatar
Sounds like it could be the FITV (fast idle thermo valve) located beneath the throttle body, probably not closing after warm up which in effect is causing a vacum leak, try removing it and giving it a bit of a clean. To test the FITV remove air filter pipe from throttle housing to find 2 holes in side housing before butterfly, get car to opperating temperature and cover up the bottom hole with your finger and if idle settles down then that is your problem.
Old Mar 1, 2007 | 07:41 AM
Marty's Avatar
I'd say it's the TPS, best way to find out is just un plug it while the car is idling.
Old Mar 1, 2007 | 10:31 AM
Ej1Rider's Avatar
lol this thread started 12/18/05, and said he got it fixed, thanks for your help tho civic_coupe.
lol and marty didnt even read the date lol
JBaris
Nov 27, 2010 04:47 PM
JBaris
Nov 22, 2010 03:56 PM
kroopz
Mar 26, 2010 10:35 AM
Jeremy102579
Mar 17, 2010 07:18 AM
plasticboob
May 19, 2006 02:01 AM
