'93 Civic: Instrument Panel Light Problem
Old Mar 30, 2010 | 07:08 PM
Check for a short in the taillight and parking light bulb receptacles.
Old Mar 30, 2010 | 07:14 PM
Robzek's Avatar
How can I check? and if there was a short would the brake lights still work? cuz mine do
Old Mar 30, 2010 | 07:18 PM
Yes, the brake lights would still work. It's the same bulb but the bulb has two separate filaments for the taillight or brake light.
Remove the bulb and look for any obvious damage, burning, or corrosion in the socket where the bulb inserts. Also inspect the bulbs and the wires at the rear of the socket.
Old Mar 30, 2010 | 08:02 PM
Robzek's Avatar
I checked the taillights and on the passenger side the brake light socket looks like it over heated and melted from the top, also the light bulb is damaged, you think that might be the problem? i tried putting the bulb back in the socket and it wont go in cuz of the melted plastic around the socket
Old Mar 30, 2010 | 08:04 PM
You likely found the problem. You'll need to replace the socket.
Old Mar 30, 2010 | 08:14 PM
Robzek's Avatar
I installed the bulb back in the socket applied the brakes and the bulb does light up even though it's damaged
can the socket be found at any auto parts store?
Old Mar 30, 2010 | 08:55 PM
The part of the socket that powers the brake light is fine. The part that powers the taillight likely has the short. You can try some auto parts stores, but if they don't have it, go to some local junkyards. The last resort would be the Honda dealer.
Old Mar 31, 2010 | 03:00 PM
Robzek's Avatar
I found a complete taillight harness from a wrecked civic so I swaped mine out, I installed new bulbs and a new 10a fuse, turned on my headlights and the fuse burned again, I dont know what to try next
Old Apr 1, 2010 | 02:31 PM
Robzek's Avatar
I checked the socket on the plate lights and they are fine, I don't know what else to try
Old Apr 3, 2010 | 11:40 AM
carter136's Avatar
im haveing the same problem. my fuse is good bulbs and all recepticles are fine jumped the red and black wire but no luck. please let me know how to fix it.
94Civic94
Jun 23, 2008 06:42 AM
JdotVince
Mar 24, 2008 05:29 PM
dpolishsensation
Aug 6, 2007 04:47 AM
The Scales
Feb 16, 2006 02:16 PM
civicguy1xxxxx
Aug 15, 2004 12:22 PM
