93 dx coupe getting no juice HELP!
Old Jan 13, 2008 | 08:08 PM
GangstaMas1's Avatar
Default 93 dx coupe getting no juice HELP!
All right so i changed out my alternator the other day, and now i'm not gettin any power. the battery is good, its been tested and i tried it on another car... starter is good too any ideas?
Old Jan 13, 2008 | 08:12 PM
Default RE: 93 dx coupe getting no juice HELP!
What year and model Civic do you have?
How do you know the starter is good?
Does your ignition switch work?
Old Jan 13, 2008 | 08:17 PM
its neither, i'm not getting any type of lights, between the interior or headlights im at my witts end, i'm almost to the point where idc about it starting i just want some lights or the radio to come on, and its a 93 dx coupe
Old Jan 13, 2008 | 08:32 PM
Edit:
Check whether fuse 41 or 39 in the under-hood fuse relay box is blown.
Also check whether fuse 12 or 24 in the under-dash use relay box is blown.
Old Jan 14, 2008 | 07:13 AM
When you attempt to change the alternator without disconnecting the battery, there's a very good chance of blowing one of the main fuses in the underhood box.
If you did disconnect the battery, make sure it is securely reconnected, also check the main fuses. There's a chance your new alternator is shorted or you have the big white wire at the alternator touching ground by accident.
Old Jan 15, 2008 | 01:09 PM
Bump back to page 1. The main fuses are in the fuse/power distribution box next to the battery, they are larger square units held down with screws instead of plugging in.
Savage
May 21, 2012 05:56 PM
pogobill
Apr 3, 2012 10:54 AM
Mcgarvie
May 29, 2011 11:21 AM
riceburner700
Nov 1, 2005 07:44 PM
Cleft_Asunder
Jul 22, 2005 11:43 PM
