Engine dies, not getting juice?
Old Jul 10, 2005 | 07:43 PM
Cleft_Asunder's Avatar
Default Engine dies, not getting juice?
My 98 Civic has 86000 miles on it and it's "putting" as if it's not getting enough fuel. I replaced the fuel filter and I'm still experiencing it. Today while traveling through Reno my engine turned off at a stop light; it wasn't pretty, but I managed to get it going again by applying gas to the pedal. Once the car gets going, it doesn't stop. But when I stop the vehicle, it's ready to die.
Now, I was thinking it's the fuel injectors. I haven't tried the expensive fuel injector cleaner yet, and I'm wondering if it's worth it.
Thanks,
C_A
Old Jul 10, 2005 | 09:22 PM
Default RE: Engine dies, not getting juice?
Any ideas?
Old Jul 10, 2005 | 10:02 PM
Remmy's Avatar
I had the same problem... put in fuel injector cleaner... stuff like that that you dump in your gas tank before you fill up... also carbon cleaner helps too. I have a '00 civic with 70k miles and it fixed it within a week. No worries man, its only a $10 tops fix.
Old Jul 13, 2005 | 12:16 AM
Thanks, I'm going to try it.
Old Jul 22, 2005 | 11:43 PM
Elnyne's Avatar
if that doesnt fixit have your injectors professionally cleaned this is usually about $60-$80.00 (I'm in central indiana)
also have your computer tested you could have a bad fuel map driver expensive but easy to fix
drewrussell2011
May 17, 2014 07:57 PM
Savage
May 21, 2012 05:56 PM
pogobill
Apr 3, 2012 10:54 AM
NIKE H34D
14
Jul 20, 2010 07:49 AM
GangstaMas1
Jan 15, 2008 01:09 PM
