94 civic 1.6l dohc vtec zc engine ecm...
Old May 18, 2013 | 02:08 PM
josebmw's Avatar
Default 94 civic 1.6l dohc vtec zc engine ecm...
Hi guys i was searching on the forum for awhile , wondering to know if somebody have any information about a ecm fittment. My mother has a CIVIC SI sedan with a 1.6l dohc vtec zc engine, this vehicle is out of usa, ecm starting acting weird, when the engine is off and trying to turn it on, it just cranks happens while the CEl light is on, after few minutes and after the MIL light is off teh engine starts normally and the car runs fine, this happens at least 3 or 4 times a day.
Im suspecting a bad ecm. Now, my question is; my ecm number should be 37820-p30-j50, which other ecm could fit on this car? will the sohc vtec ecm fit on this vehicle?
Any help will be apreciated, thanks in advance.
Old May 18, 2013 | 08:38 PM
Resolder or replace the main relay first. A bad main relay will do exactly what you describe, and it is a much more common problem.
Old May 19, 2013 | 03:23 AM
josebmw's Avatar
Hi mk378, thanks for the advice. Is that main relay soldered directly on the ecm or is it located somewhere else on the vehicle?
My mother told me that the mechanic that is working on the car changed it already, but i do not thrust too much on new parts specially if them are aftermarket parts. I had too many bad experiences with after market parts
Thanks.
Old May 19, 2013 | 03:39 AM
josebmw's Avatar
Default .
I got it. Im going to try to talk with the mechanic and give him specific instructions to try to fix this issue.
Thanks.
Old May 19, 2013 | 06:42 PM
MBrent's Avatar
July 2010 ROTM
DOHC ZC were not vtec. If it is vtec, it is a b16. This makes a pretty big difference when replacing the ecu. Just a heads up.
Old May 20, 2013 | 02:38 AM
josebmw's Avatar
Hi there,
Thanks MBRENT for the info, i did a small investigation over here and i figured that out. My mother's car computer is P29-T51. I guess that a p06-a51 will work almost perfect as soon as the CE light stays off. She never goes over 50MPH.
danomatic93
Oct 11, 2010 04:01 PM
norman
Nov 22, 2009 09:40 PM
danomatic93
Jun 8, 2007 07:24 PM
b16avtec
Dec 8, 2006 07:44 PM
kazunori
Mar 20, 2005 08:22 AM
