94 civic 1.6L Trans woes
Im repairing my neighbors civic and she said the car went into gear. then when she rode up the street and stopped at a light and attempted to go again. it wouldn't go into gear at all. (she believes she heard some type of clunk.thud noise) Claims the shifter will go into the all gears but no response when in gears
The car is not by me so i will haft to be vague on some things :-(
Does the speedometer go up (even though the car is not actually moving) when you put it in gear and try to go? If so it is an axle problem such as a broken CV joint or one of the axles came loose from the transmission, which is common after recent service involving removing an axle. (The speedometer going shows that the gears in the transmission are turning but the power is not reaching the wheels.)
just found out from her that the mph gauge does still go up. so thank you very much for suggesting that. you just saved me some head ache i believe. NOw to get the darn car down here to me. is there a preferred side i should be looking at?
It could be either side. With both front wheels off the ground and the transmission in Park, turning one wheel by hand should make the one on the other side turn in the opposite direction. If it doesn't, look for where the motion is stopping.
bonzitre
Jan 21, 2007 08:51 PM
