94 Civic died and some electrics wont work
Old Dec 5, 2011 | 04:16 AM
jonnyk's Avatar
Default 94 Civic died and some electrics wont work
i have a 94 civic. last nite when i turned on the wipers/window washer the car died. when i pulled over i realized the wipers, window washers and electric windows dont work but all other electrics (heater, radio headlights etc) are fine. I havent been able to start the car since. Ne ideas what the problem cud be?
Old Dec 5, 2011 | 04:33 AM
Check the main fuses in the box under the hood. I think there are two fuses feeding to the ignition switch, for different functions. It could also be a bad ignition switch or a bad ground on the engine (if it won't crank either). Note that the headlights bypass the ignition switch entirely.
Old Dec 5, 2011 | 07:30 PM
1) Dash fuse 14 is blown.
2) When you turn the key to ON(II), do the cluster warning lights (battery, CEL, oil pressure lights) turn on?
Old Dec 6, 2011 | 01:12 PM
jonnyk's Avatar
yesterday when checking the fuses i realized the wiper fuse was blown changed that and the car started straight away and ran fine for the day. tried starting it earlier and it was only turning over slowly and took about 20 seconds to start ne ideas wat could be causing this?
Q336814
Oct 20, 2010 07:05 AM
aksurber623
Sep 26, 2008 05:01 PM
duffa66
Apr 29, 2007 09:26 AM
ricerocket
May 13, 2005 09:19 AM
AndyI
Oct 6, 2004 09:36 AM
