Can't get SRS error codes from 98 Civic EX
Old Dec 3, 2011 | 05:53 AM
Kodiak98's Avatar
Question Can't get SRS error codes from 98 Civic EX
I have a 1998 Civic EX that has the SRS ight on all of the time. The light will not re-set, so there must be a problem. I have tried to jumper the service plug, and the data link pins 4 & 9, but the SRS light won't blink any codes. It just stay,s on. Does anyone have any idea's.
Old Dec 3, 2011 | 07:34 AM
SRS has to do with your airbags, and nothing to do with Check engine lights related to your engine which are pulled from the service plug. Usually, if a part of the SRS system is disconnected, the light will come on. Here is a DIY guide on resetting the light.
How-To: Reset your SRS light - ClubCivic.com - Honda Civic Forum
Google for more results and/or youtube videos.
Old Dec 3, 2011 | 08:51 AM
Kodiak98's Avatar
I know. That's what I'm saying. The SRS light is on constantly and it won't re-set. This tells me that there is an actual problem in the SRS system. According to everything I've read, I should be able to get the light to blink the SRS error code by jumping the #4 and #9 pins in the data-link connector. This procedure does nothing. The SRS light just stay's on.
Old Dec 3, 2011 | 01:51 PM
Check that the SRS module is actually installed and the fuse is OK. If the module is completely dead or missing, a circuit in the cluster will default to having the light on all the time.
Old Dec 6, 2011 | 01:25 PM
Kodiak98's Avatar
srs fuse is good. The light will reset, and then come on again.
fivebells
Aug 9, 2014 06:10 PM
j92dx
12
Oct 19, 2008 10:39 AM
hondamom
Jan 13, 2008 05:47 PM
MindDesign
Jan 4, 2008 01:55 AM
combos
Dec 21, 2007 11:27 AM
