94 civic lx battery light on help
okay the battery light on my 94 civic lx came on a couple of days ago i pulled the alternator took it down to advanced auto and had it checked and it checked good put it back in and the light was off half a day later it came back on battery is gettin drained i dont know what too do but when its runnin and i discconect the positive cable the car dies is that normal for a honda pls let me know thanx
You probably need a new alternator. Much like starters, they get intermittent before going completely dead.
Don't do the disconnect the battery with the engine running test. In a modern car it risks causing a power surge that can damage the electronics. The proper test is to measure the battery voltage with the engine running. If you don't have a voltmeter you have no business messing with an electrical system.
With the engine off, touch the red (+) probe to the red (+) positive battery connector and the black (-) probe to the black (-) ground battery connector. The voltage should be around 12.5V.
Do the same with the engine idling to spec under no load (all accessories off). The voltage should be around 14.5V.
Do the same with the engine idling to spec under load (A/C and blower on max; brights on). The voltage should not drop too far below 14V.
milhouse
Sep 26, 2013 05:31 PM
2468wdya9
Dec 14, 2012 10:48 AM
Knobmeister
Apr 14, 2012 05:47 AM
blatin
Jun 11, 2007 07:42 PM
addiction2bass
Jul 24, 2006 08:57 PM
07, 1994, 94, 98, battery, civic, dx, group, honda, intermittent, intermittently, light, lx, size, troubleshooting
