94 Civic Wont Start
Old Feb 5, 2006 | 12:59 AM
jwsimons's Avatar
Default RE: 94 Civic Wont Start
also check the fuse in under hood relay box... there are some side by side.. and then four end to end, check the second one, thats your ecu fuse, should be a 7.5a
Old Feb 5, 2006 | 01:01 AM
Boost231's Avatar
the g/f was just driving the car made a u turn and went to go up a slight slop to the parking lot and it just shut off. i will check the alternator stuff and i checked the ground around there as well. please let me know if you remember more
brent
Old Feb 5, 2006 | 01:13 AM
jwsimons's Avatar
i have been reading the whole electrical section on that car, the only common thing i find is that those two systems share a common ground, here is everything you ever want to know about that car, (and 10 things you didnt..lol)
check page 1001 to see what im talking about
http://www.televar.com/soxen/92-95-helms.pdf
Old Feb 5, 2006 | 01:19 AM
my_hidden_romance's Avatar
does the car even turn over?
could be the timing belt snapped on her..
Old Feb 5, 2006 | 01:23 AM
jwsimons's Avatar
i just remembered.. it was so simple i forgot..... the nut that holds the rotor in place... see if its there.. happened to me once, everything seemed to work but no spark etc.
same exact symptoms, i was even going up a small hill when it happened!!!
Old Feb 5, 2006 | 10:24 AM
AgentofDarkness's Avatar
Even if the rotor was loose and it wasn't sparking, the injectors would still fire. The fact that the injectors don't fire and the plugs don't fire is a little fishy. Do you know if teh injectors are getting a signal to fire. There is a probe thing that you can use to test it. You hook it up to the connector on the injector and it will light up whenever the injector recieves a signal to fire.
Old Feb 5, 2006 | 01:45 PM
Boost231's Avatar
well i found out what the problem is. the timing belt went. so my question is did it tag the valves or is it a none interference motor.
Old Feb 5, 2006 | 10:40 PM
jwsimons's Avatar
i dont think you have a non interference engine, however, i lost a belt before and no harm was done. unless your g/f heard a pinging sound you are probably o.k. points to romance on this one!!!
that link i sent you should give you step by step on installing the t.b.
Old Feb 5, 2006 | 10:58 PM
Sphinx_1's Avatar
I replaced the timeing belt on my brothers 94 civic and it didnt do any damage. If you are planning on doing this yourself make sure you replace the tensioner pully. That is actually what broke the belt on his car, the tensioner pulley locked up and broke the belt. I believe if you get the timeing belt kit from someone like Oriellys the tensioner comes in the kit. You probably want to ask them to make sure, but I think it does. Someone in forum probably knows also.
David_S
Oct 24, 2013 10:06 AM
bmelloh
May 16, 2009 08:01 PM
black99ta
Aug 2, 2005 05:24 AM
Aztec007
Jun 15, 2005 04:06 PM
AndyI
Oct 6, 2004 09:36 AM
