'94 DX Idle Issues After Driving
Old Oct 20, 2011 | 08:38 PM
Deltree's Avatar
Default '94 DX Idle Issues After Driving
I thought this problem was just going to go away but it still persists.
Originally, after I replaced timing belt and did all that good stuff, when I start the car it idles high (1500ish) then after 10-15 seconds drops down to 800ish. It only did that a few times.
Every single time, after I drive the car and then put it into park (when I am done driving it - could be after 10 minutes or 30 minutes) it starts at around 1500ish then drops down to 800ish after a second, then jumps back up to 1500ish and back down again. It continues to do this. I am not sure how long it lasts for - longest I have let it sit is about 7-10 seconds. After a week of driving it every day it's still doing that.
Also, when the car goes from 3rd to 2nd and then 2nd to 1st gear (if I am stopping for a red light for example) it jumps from 800ish to 1500ish RPMs. I imagine going down a gear would increase the RPMs however it feels like someone tapped the gas (I didn't) and jumps forward a little.
Any thoughts? Its an automatic and I've replaced several things on the car after it died on me. There's a bit of history with it if it helps. Thanks.
Old Oct 21, 2011 | 06:38 AM
rburch77's Avatar
Check the IACV and if its dirty clean with Carb cleaner.
Old Oct 21, 2011 | 06:57 AM
Deltree's Avatar
Is it safe to assume there's no good way to check if it is dirty without taking it out? lol After reading on what the IACV is, makes sense now that that is what the issue could be. I will do that either tonight or tomorrow. Thanks.
Old Oct 22, 2011 | 11:29 AM
Deltree's Avatar
I checked the IACV and it was a little dirty. I didn't take it all the way out, I only un-did the two 12 mm bolts and I used Brake Cleaner instead of Carb Cleaner. It certainly looked better, and since I was in a hurry I couldn't let it sit for the full 15-20 minutes - more like 5 minutes and wiping it off with a rag.
Anyway - both problems still persist. Should I try again using Carb Cleaner and actually taking it off all the way or is there something else that is wrong? Thanks.
Old Oct 24, 2011 | 06:10 AM
Deltree's Avatar
Any more thoughts? Thanks.
Old Oct 25, 2011 | 02:40 PM
Deltree's Avatar
Alright well I completely took the IACV off this time, even though it looked clean for the most part I went to town on it. Cleaner, rags, can of air, the whole 9 yards. If it wasn't for being 17 years old - it would look as good as new
Anyway - I drove it for about 20-25 minutes, on street and on highway - and put it in park and it definitely did not fluctuate the idle like it did before. However, it is still feeling/acting/sounding weird when it goes from 3 to 2 and from 2 to 1.
This is an automatic. Should I be using D3 or D4 for the most part? I've been driving it in D4 all the time but since about 3-4 days ago, I am driving in D3 if I don't need to go over 40 mph. Thoughts?
EDIT: Here are some pics of the IACV after cleaning.
Old Oct 26, 2011 | 05:19 AM
Deltree's Avatar
Update - I was wrong with my previous post. I drove it to work this morning and put it in Park and the same thing happened with the fluctuating idles. Any thoughts?
civicowner2010
Feb 16, 2012 01:52 PM
JBaris
Nov 22, 2010 03:56 PM
mill$civic
Nov 18, 2006 05:56 PM
caged_soul_seeker
May 20, 2006 11:16 PM
mill$civic
Jul 13, 2005 08:12 PM
