95 civic 1.6 vtec
Old Jun 10, 2007 | 01:37 PM
danogod's Avatar
Default 95 civic 1.6 vtec
my wife pulls up to the gas pump and turns off the car.fills up and now it wont start.i replace the starter and still nothing,battery is 100 percent and all lights work and are not dimming but i am getting nothing.i checked all fuses and about to strike a match.it was not doing anything prior to this , it just will not start.
Old Jun 10, 2007 | 01:51 PM
defjamon22z's Avatar
Default RE: 95 civic 1.6 vtec
did it crank or just dont doesnt do anything? maybe ur battery connection is not making good contact? maybe ur alarm is mess up and not closing the circuit in the kill switch relay? maybe ur fuel pump stop responding? maybe u pop a fuse? but a good chance ... maybe ur igntion in the spark plug distributor cap gone bad? check all that
Old Jun 10, 2007 | 02:16 PM
Masonn's Avatar
probably the fuel pump, with a fuel pump gone, the engine will turn over, and over, and over... but it wont start.
Old Jun 10, 2007 | 02:45 PM
I think he's saying it won't crank. Jump the starter by taking the little wire off the starter then hooking a jumper from the little terminal on the starter to the big one that goes to the battery. The engine should crank. If it doesn't, it's the starter, battery, or something in between. Could've gotten a bum starter.
Old Jun 10, 2007 | 02:49 PM
danogod's Avatar
i had the new starter checked,what i mean is i turn the ignition switch and i get nothing.all the lights come on but i get nothing not even a click from the starter.
Old Jun 10, 2007 | 10:00 PM
xramseyx's Avatar
Well id just hope you didnt fill up for 3.85$ a gallon like it is here... id be furious! lol
Old Jun 11, 2007 | 04:43 AM
danogod's Avatar
has anybody else had the safety neutral switch go out,i looked in the floor and found this little rubber stopper had fell to pieces,could this be it and if so how do i go around it.
Old Jun 11, 2007 | 08:27 AM
mlobitz's Avatar
Member
Are the battery connections clean and tight?
Old Jun 11, 2007 | 08:50 PM
Masonn's Avatar
if nothing, try and push start it! (if its a 5spd) put it in 2nd gear, push in the clutch, get the car rolling pretty fast (walking pace), and then jump the clutch then push it back in quick. the car should start, only use this when u have to. If she don't start, u might have a bigger problem then u think, and should get it checked out by a professional
Booger
EK Swaps
Aug 9, 2011 10:11 PM
CarmineD187
Sep 16, 2007 04:17 PM
ryantann
Feb 21, 2006 09:50 PM
mahmi
Aug 25, 2005 09:39 AM
kcmercedes
EK Swaps
Sep 24, 2004 11:05 PM
