95 Civic Engine
Old Sep 9, 2007 | 10:22 AM
marc0834's Avatar
Default 95 Civic Engine
Would anyone know if how much Is to spend for a Engine Overhaul.
I Mean Change the Piston Rings , Value Cover Gaskett , Gap VAlue. The works !!!
Old Sep 9, 2007 | 11:45 AM
Default RE: 95 Civic Engine
well for a complete rebuild from a quality shop it can be expensive.... doing all the block and cylinder work then blue printing the whole motor to buy the PERFECT fitting parts will all jack the price up!
BUT if you just have some burning oil removing the head and pulling the pistons and replacing the rings can be easy enough... but i would sugest doing 1 piston at a time... that way ya dont get anything backwards and all the bearings back in the same exact spot!
other than a quick ring job and headgasket.... if anything realy bad with it it would probably be cheaper to look for a low milage imported motor or a low milage rear ended vehicle...
justin1138
May 9, 2007 06:22 PM
Kingzlei
May 5, 2007 04:06 AM
Xtreamist06
Aug 30, 2006 09:14 PM
