95 ex cruise control
Old Nov 7, 2008 | 08:34 PM
ashcheerit2000's Avatar
Default 95 ex cruise control
i have a 95 ex that cruise dont work on, i have swapped everything from dash button to steering buttons and the big unit under hood took it off brothers car that works purfect, all vacume lines are hooked and cables are hooked and not broke,the light doese come on that is on the dash when you press it but nothen else happends when you try to turn it on by the steering wheel buttons what should i look for? if wires which ones or is there a computer or something n where would it be located?
Old Nov 7, 2008 | 08:47 PM
Have you checked under-dash fuses 15 and 24, as well as under-hood fuse 42?
To download the 92-95 Civic manual, click the manual link in my signature.
Old Nov 7, 2008 | 09:05 PM
I have checked all of the fuses that are clear ones under dash and hood
Old Nov 7, 2008 | 09:06 PM
Doing the input tests detailed in my post above should identify the problem.
Old Nov 7, 2008 | 09:14 PM
ok thanks.. i knew the cruise control unit box was somewhere in the car.. I'm still trying to figure out what the big box thing is that is in the trunk on the passenger side my lx didn't have that..
Old Nov 8, 2008 | 02:20 AM
Old Nov 10, 2008 | 05:12 AM
If it's a manual transmission, the clutch pedal switch is often the problem. The lower switch will drop out the cruise control (or prevent it from engaging) when it detects the pedal is pressed even slightly. Check that the rubber pad on the pedal arm, which presses the switch button when the pedal is all the way up, is still there.
Old Nov 10, 2008 | 12:47 PM
harne_kyle's Avatar
are these diognostics the same for the 96 also?
Old Nov 10, 2008 | 01:20 PM
Not sure. You can check the 96-98 manual at the link in my signature.
dmsteele92831
Jul 23, 2007 11:10 AM
Cappelle
Apr 21, 2005 01:30 PM
civicracer_44
Feb 3, 2005 07:04 PM
civic9988
Oct 24, 2004 07:22 PM
frameb
Jun 14, 2004 11:28 PM
