95 Honda Civic Turn Signals and Hazards don't work :(
Well as the title says my 95 Honda Civic turn signals nor hazards want to work
. I have no idea what could be the cause. I changed the bulbs, changed the fuses, chaged the flasher, and now I have no idea what to try
. My guess was goin to be the switch on the steering column, but it would make no sense because the headlights work just fine and the hazards aren't even on the switch
. I just need some help and have been looking at forums, but have not found one with the same problem. Any help would be appreciated. Thanx.
Try a new hazard switch, since all the circuits pass through it. Should be able to get one at a junkyard if you can find one with cars that old.
A few basics: The fuse for the hazards is under the hood. The fuse for the regular blinkers is under the dash. The regular blinkers will only work with the key on.
you probably need a new clock spring..
that happened to my car. signals wouldnt work neither would cruise control or the horn, i replaced it now its fine. and it doesnt have to be all of those at a time, it can be just one
