96 Civic woes
Old Jan 11, 2015 | 01:29 PM
beanb26's Avatar
Default 96 Civic woes
I was driving it today and it just quit running. I have fuel, the fuel pump is working but after that I am not sure where to start looking. When it stopped there were not any warning lights or anything like that came on. I figure it is ether not getting any spark but how would I check that? I would think that if it was a spark plug it would have just started running rough, would the distributor have caused this all of a sudden?
Old Jan 12, 2015 | 06:43 AM
Common reasons for this:
- Bad ignition switch. Pull the hand brake handle up and watch that the BRAKE light on the dash stays on both with the key on and while cranking. Also check that the check engine light comes on when you turn the key on but don't crank, and goes out after 2 seconds.
- Stripped timing belt. Take the oil cap off and watch for the rockers to go up and down when you crank.
- Blown coil. Pull one spark plug wire out and put a spare plug in the end. Hold the plug against the engine and watch if the plug sparks when you crank.
- Distributor rotor screw fell out. Remove cap and inspect.
Old Jan 14, 2015 | 08:05 AM
beanb26's Avatar
Thanks for the input, replaced the coil and fired right up!
Jymmm
Dec 5, 2013 09:13 AM
The_Ga_Heretic
Dec 6, 2012 02:54 PM
MartinL_Vtec
Aug 26, 2012 04:15 AM
us25076
Aug 12, 2010 02:55 PM
35neutral
Nov 19, 2007 09:32 PM
