97 civic no spark
Old Jan 19, 2011 | 09:34 PM
dreadrea's Avatar
Default 97 civic no spark
alright after a year of sittin put a new battery in my honda( z6 head with a y7 block)
now im not getting any spark, tried a new coil and icm. checked fuse and now at a stand still. it was running when i took the battery out a year ago.
Old Jan 20, 2011 | 05:06 AM
Some basic checks: check that CEL cycles on and off and the oil and battery lights come on and stay on when you turn the key on and don't crank. Check that the BRAKE warning light stays on while you try to start with the brake handle pulled up. Check that the camshaft rotates when cranking (remove the oil cap and watch for the rocker arms to go up and down). Scan the ECU for codes. Check that power is reaching the distributor on the black and yellow wire.
Old Jan 21, 2011 | 10:41 AM
dreadrea's Avatar
K got power to the dizzy and coil just no spark, also the check engine dose not come on
Old Jan 21, 2011 | 03:10 PM
If check engine does not come on at all (assuming bulb has not been removed), that means the ECU is not powering up. Check the ground wires on the thermostat housing. Pull a schematic of the car (I don't have the '97 handy) and check that power is reaching all the power wires on the ECU.
wongthao
Nov 17, 2006 05:22 AM
boostnub
Oct 25, 2006 05:59 PM
rok_spitfighter
Oct 18, 2006 02:05 PM
onetrackmind
15
Aug 18, 2005 08:06 AM
jnash
May 17, 2005 12:19 PM
