'97 Distributor removal???
Old Jul 24, 2011 | 12:27 PM
Old Hippy's Avatar
Default '97 Distributor removal???
I've got a heater hose leaking, and it's under the distributor. But before I go out in the garage and tear into this problem...I need some confidence.!!!!! I gotta remove the distributor to get to this hose, and want to know what problems I might encounter if any.?? Is putting this thing back together going to cause timing issues???
Old Jul 24, 2011 | 01:55 PM
Old Hippy's Avatar
Also, can SOMEONE please tell me how to unplug the wiring to the Dizzy??? I can't unlock the plug. What is the secret??????
Old Jul 24, 2011 | 02:55 PM
I highly recommend against removing the dizzy, as you will have to redo the ignition timing afterwards. Unless you know how to do this, that is. Then by all means, go ahead. All you have to do is remove the 3 bolts that hold it on. They're basically a triangle. You can't miss the one on the top.
The trick to undoing the plug is to use a screwdriver to pry the plug itself off the metal it's mounted to. With one hand, press the plastic release on the whole plug, while pushing with a flathead screwdriver to pull it off the metal. Then it will effortlessly come apart.
Old Jul 24, 2011 | 05:16 PM
boiler1's Avatar
All i do is make a mark with a screwdriver across the dizzy/head surface, so that when I bolt it back on its in the exact same position.
Extension with articulating joint helps get to the bottom bolt.
No secret to the wiring plug. Push button and pull.
Old Jul 24, 2011 | 06:06 PM
Like Hobo said, the plugs have a locking feature. You have to take them off of the metal bracket first, then they can be unplugged.
Old Jul 25, 2011 | 12:49 AM
Old Hippy's Avatar
Thanks for the tips...!!!
Old Jul 26, 2011 | 12:30 PM
Slammed98silvercoupe's Avatar
maybe a little too late but dont take it off unless you have too. I changed the hose right below the dizzy, what helped me alot were a pair of long curved needle nose pliers.
Old Jul 26, 2011 | 06:14 PM
Old Hippy's Avatar
Default Job Done.....Thanx to ALL
Got 'er Done....Removal of Dizzy was a piece of cake. Got the plug unlocked, took Dizzy out, fixed busted hose by cutting about an inch off, put everything back together....in 30 mins.!! Thanks for the tips and confidence.!!! <3
Old Jul 26, 2011 | 06:15 PM
Old Hippy's Avatar
It is SOOOO much easier taking the Dizzy out.!! Believe me.!!!!
jerryc41
13
Nov 17, 2010 08:39 PM
upssuprvsr41
Jan 10, 2009 07:36 PM
baker7598
Jun 21, 2005 11:47 PM
ohbiskits
Dec 6, 2004 09:32 PM
