97 EX leaking oil driver's side
Old Nov 2, 2011 | 09:08 AM
G37J4K3D's Avatar
Default 97 EX leaking oil driver's side
Hi there,
I bought my civic a few months back and I have to say I love the car. It's needed a few things, but it has never failed me!
Anyway, today I discovered an oil leak on the bottom of the engine, driver's side. It appears to be leaking where the oil pan meets with some shaft (I don't know a ton about cars, just enough to get by I guess...) and it leaves little drips wherever I go. If I'm not mistaken, that would be the crankshaft?
Anyway, a photo... Name:  photo.jpg
I have a friend who would help me with the job. I just have to know what seals to pick up.
Thanks
Old Nov 2, 2011 | 09:30 AM
droopy128's Avatar
If it is the front seal, you might as well do the timing belt job and change out the rest of the items associated with t/b job.
Old Nov 2, 2011 | 09:33 AM
Yes it looks like the front crank seal is leaking. Would need to remove a few parts to see clearly, at that point you're ready to change the timing belt. It's always a good idea to replace the timing belt after buying a used Civic since you can't know how old the one on it is.
Old Nov 2, 2011 | 09:50 AM
G37J4K3D's Avatar
That's what I thought. Timing belt, crankshaft seal, water pump. Anything else?
More of an opinion question: The car just turned 200K. Would it be worth it? If not, I'll look for something else. I would really like to stick to Honda... I love the way the car drives!
civicrevolution
Apr 3, 2011 04:27 PM
RonJ
Jun 15, 2010 01:39 PM
oilltd
Jun 10, 2008 04:06 PM
10isAce
Feb 21, 2007 09:19 PM
