97civic 2door auto*help*
Old Nov 23, 2010 | 07:27 AM
123mdg's Avatar
Default 97civic 2door auto*help*
Car wouldnt start
jumped it, checked alternator and battery, alternator was putting out right amount of power but the battery had a bad cell
replaced battery
bout 10 days later check engine light came on
next time i went to start it nothing happened
wont take a jump
i see a little flicker of light on the vent button for a split second, when i turn the key
and maybe hear the whirring of the fuel pump?
Also wont shift into neutral
Any comments suggestion questions would be hugely appreciated
Thanks HCF
Old Nov 23, 2010 | 03:00 PM
crusty juicebox's Avatar
is it a manual transmission? if so your clutch interlock might be faulty.
Old Nov 24, 2010 | 03:23 AM
Likely a bad connection at the battery. Turn the light switch on to establish a load on the system. Measure voltage at the battery posts (confirming the battery is live)-- then at the terminals.
Old Nov 24, 2010 | 04:29 AM
123mdg's Avatar
Its an automatic
MK- i imagine you mean the headlights?
Will call over a buddy with voltmeter and try that out
I am almost close to getting it towed and getting screwed by a mechanic... ouch
Thanks a million for your thoughts and suggestions
Old Nov 25, 2010 | 08:04 AM
123mdg's Avatar
Issue solved
It was a bad battery connection
Replaced the terminal clamps and resolved the issue
Thanks MK and the HCF
rededdedone
Mar 29, 2014 12:34 PM
rededdedone
Mar 25, 2014 07:23 AM
97civicturbo
16
Mar 22, 2007 12:09 PM
benfredjosh
Jun 12, 2006 10:23 PM
CiViCwItAsWaP
Dec 6, 2005 08:41 AM
