starting problem
When I do a cold (first of day, regardless of temp) start, it takes 8 cranks to start up, but it always does.
However, if I turn the key part way before i start it, i can hear the fuel pump pressurize and it starts in about 3 cranks. it also starts normal after the first start of the day. It has only been doing this the last couple months.
I have a new battery/terminals, new plugs and wires, new fuel filter. any ideas on how this can be fixed?
If there's a leak other than inside the gas tank, you would smell gas when driving. Most likely, it is leaking back through the check valve in the pump. The gas drains out of the lines back into the tank while the car is parked.
djt
Jun 21, 2008 07:48 AM
totenkopf
May 31, 2007 03:36 PM
raphn
Jun 14, 2004 02:07 PM
