98 Civic Ex - Loss of power, engine sputtering
Old May 21, 2020 | 05:32 AM
Alucard5715's Avatar
Default 98 Civic Ex - Loss of power, engine sputtering
Put oil in my car last night, been a while since my last oil change and cause of the vivid stuff, been having trouble finding oil, so I ended up putting 2 quarts in. This morning on my way to work, it wouldnt go past 65mph (3.5krpm) on the highway, engine was kinda sputtering, like it was bogged down almost hesitating. When i got back on surface roads closer to work. It would be fine from a full stop, to about 25ish-30 mph and up then it would start acting up again.
kind of early into the winter I had to check engine light come on and it said that I needed a new knock and O2 sensor. The check engine light went out after a little while with no other issues. It just came back on recently with the same code. We've had some super heavy rain this week and I had you drive in a decently sized cool water to get to work, so I think between possibly getting water in my exhaust and the O2 sensor, the my OT sensor is just completely ****ed now.
Does my reasoning sound good or am I over looking something maybe? My dad suggests a tune up, spark plugs, wires, etc. I don't know if thatll fix it tho.
My Cvic is close to 250K miles if that helps any.
Old May 21, 2020 | 11:41 AM
StifflersMom's Avatar
Cat Fuсker
Try reseating the O2 sensor connector. You might have corrosion on the contacts. Bogged down could also mean a clogged cat if you're burning oil that's a distinct possibility.
Stiegr
Jul 7, 2015 05:20 AM
98hatchem
Apr 12, 2012 06:39 AM
kripkrip422
Jan 3, 2011 01:15 PM
yairsaenz83
Feb 22, 2007 07:41 PM
tuolumne
Nov 7, 2006 11:52 AM
