98 civic maitenence needed
Old Jan 29, 2008 | 02:14 PM
slideking's Avatar
Default 98 civic maitenence needed
There is this red thing that says maitenence needed. At one point it was green.
It turns color by rotating like the mileage numbers do.
What would cause this? I think it is different than the check engine light.
Old Jan 30, 2008 | 12:12 PM
Firehawk989's Avatar
Default RE: 98 civic maitenence needed
Yea, it is in fact connected to your odometer inside the cluster. It turns yellow just before 7500 miles, and red after 7500 miles. You can reset it by pushing your key into the little slot next to it. Same as resetting your trip meter, but you have to use your key. Its just there to remind you that you should probably at least check everything over and make sure there aren't any leaks and/or low fluids etc.
Old Jan 30, 2008 | 12:25 PM
ya if you know when you change your oil and such yourself just reset the stupid thing!
seems to long to me... i would like it if it was around 3K miles...
its nothing to worry about...
Old Feb 6, 2008 | 05:04 PM
slideking's Avatar
It is a myth that you need to change your oil on your car every 3K. However, this is true for older cars.
For relatively newer cars it is 5k.
hexumjunkie
Apr 21, 2008 09:10 AM
mombo
Aug 21, 2006 05:54 AM
JapSir
Dec 7, 2004 02:05 PM
pilot
Jul 27, 2004 09:36 AM
OCH Orange County Honda
May 25, 2004 08:58 PM
