98 coupe window washer issue HELP!!!
Old Oct 24, 2009 | 02:47 PM
gtwpoet's Avatar
Default 98 coupe window washer issue HELP!!!
i recently started having this problem with the window wipers on my girlfriends civic. the problem is they work going fast and on slow but when on INT they dont stop all the way on the bottom or sometimes dont stop at all. also when you go to turn them off they sometimes turn off or sometimes keep going. i think it might be the relay but dont know where its located or what i need to do to make sure pls help lol im new to the forum thing....thanks
Old Oct 24, 2009 | 05:17 PM
gtwpoet's Avatar
any1 out there can help i really need it...... if u know what its like dealing with a spanish woman you will help me asap lol
Old Oct 24, 2009 | 06:43 PM
Try cleaning the switch. That may be the problem. If it works fine on fast and on slow, the switch might not be sending a good signal to the wiper motor. Here's a basic DIY on how to clean the headlight combo switch and the wiper switch. Same basic principles apply to both. Worst case, you break it. Hit up a junk yard and snag a salvage one to replace it.
https://www.hondacivicforum.com/foru...ad.php?t=74275
Old Oct 25, 2009 | 08:49 PM
gtwpoet's Avatar
i will for sure try that hope i dont break it lol......ill keep u posted...
Old Oct 31, 2009 | 10:45 AM
gtwpoet's Avatar
it wasnt the problem..... the wipers will turn off on off and then go on even if u didnt touch it anyone ever heard of this????
Old Oct 31, 2009 | 02:11 PM
you gotta probe the wires on the motor and see when it has power. if cleaning the switch didnt help and the motor is still getting power then id say the switch or wires are sticking giving the motor power.
if it was just the motor not returning to the off position. but since you say it keeps coming on and off id say its the switch has gone bad and shorting out inside.
Old Nov 1, 2009 | 06:22 AM
gtwpoet's Avatar
thats wat i thought but wouldnt the fuse blow out if there was a short?
Old Nov 1, 2009 | 04:36 PM
not always.... sometimes whats shorting out is just across connection points or relays shorting out keeping them powered on.
mudhenFUF
Jan 16, 2023 08:43 PM
aeaglenfitch
Apr 18, 2009 04:00 PM
honda_f3cbr
Mar 4, 2008 09:22 AM
peterhugill
Dec 20, 2007 05:13 AM
lukbrw
Jun 9, 2004 01:36 PM
