99 CIVIC SI Speed Sensor, which one?
Old Apr 30, 2008 | 07:33 PM
Default RE: 99 CIVIC SI Speed Sensor, which one?
The vehicle speed sensor (VSS) sits atop the transmission and should be visible and accessible.
Old Apr 30, 2008 | 07:34 PM
skimmy_jimmy's Avatar
from under the hood or do i need to get underneith?
Old Apr 30, 2008 | 07:35 PM
From under the hood
Old Apr 30, 2008 | 07:36 PM
oh well **** ill go look then, i didnt think you could see it that easily
Old Apr 30, 2008 | 07:39 PM
i know this is really sad, but i honestly dont know where im even looking
Old Apr 30, 2008 | 07:41 PM
On my 97 Civic, the battery is near the firewall on the passenger side under the hood. Stand near the battery and face the engine. Look past the battery and downward toward the transmission. The VSS sticks up from the top of the transmission and has a wire harness attached to it.
Old Apr 30, 2008 | 07:44 PM
ok gotcha
Old Apr 30, 2008 | 07:48 PM
i guess im retarded... only thing i saw said HONDA P2T 12V MITSUBA
Old Apr 30, 2008 | 07:57 PM
ok im pretty sure i found it, but i cant see it its pretty blocked off
Old Apr 30, 2008 | 08:17 PM
You would need to remove the VSS to see whether the manufacturer name is printed on it. I believe this involves removal of the electrical connector and one bolt. You then carefully lift it out of the transmission. Don't let any debris fall into the hole to the transmission.
Jorge.s
Oct 22, 2008 07:21 AM
JakeyMan07
Aug 24, 2008 01:11 PM
vtec02
May 9, 2007 05:17 AM
roudan
Jan 6, 2006 02:43 PM
Auto98EX
Oct 7, 2005 10:54 PM
