Mechanical Problems & Technical ChatIf you've got a problem you just can't figure out, a noise you can't diagnose, or a check engine light that won't go away, ask about it here!
its a 87 crx si with distrubutor and try to find the negative lead from the wires at the other end of the distubutor to the conector located on the fire wall by the master cylinder
