WHICH ECU I HAVE, and which will work??
Old Mar 23, 2008 | 06:50 PM
branx's Avatar
Member
Default WHICH ECU I HAVE, and which will work??
Case 1
ok i have a crx with dohc zc motor and i heard it is possible for the car to be running on my original crx si ecu? if so how do i kno which i have,
Case 2
also im could i put a crx si ecu into a crx dx automatic?
kk thnx
Old Mar 23, 2008 | 09:49 PM
Hailchristian's Avatar
Default RE: WHICH ECU I HAVE, and which will work??
alright...well...
case 1: yes you can have that ECU in your dohc zc crx and it will work...pull the carpet back and your ecu should have a barcode on it above one of the plugs. If you can find the PM6 then its CRX si, if it says PG7 you have an 88-89 integra, and if it says PM7 you are lucky and got the ZC ecu.
Case 2.
No. DX is DPFI and the SI is Multiport Fuel injection so that wont work. And the automatic transmission and all that ....just no...it will not work
Old Mar 24, 2008 | 03:56 PM
^ an auto ecu will work in a manual; it'll throw a CEL though. I believe you can modify an auto ecu to work with a manual without throwing a CEL.
Old Mar 24, 2008 | 04:32 PM
ORIGINAL: reaper2022
yeah..i but the DX is dual port fuel injection and the si Is multiport fuel injection.
Im pretty sure you would have to do a MPFI swap for it to work.
x1mpr0x
Sep 4, 2009 07:44 PM
AuroraEP3
Apr 10, 2009 09:48 PM
ricaninacus
Oct 23, 2008 11:53 AM
ricaninacus
Oct 23, 2008 10:31 AM
lilol89crx
Jul 29, 2004 06:56 PM
